Observations and AR model
lentjeuhz
Postby lentjeuhz » Sat Aug 28, 2010 11:51 am
I have a sample of firm data for which I want to run multiple regressions. I use the same independent variables in every regression, but different dependent variables. Only complete observations (for which all variables are available) are included in the analysis. When estimating I include an AR(1) to correct for autocorrelation.
My problem is that when using different dependent variables I end up with varying number of observations, something that does not happen when I exclude the AR(1) from my model.
How can I set up my AR(1) model using exactly the same observations for all regressions?
Thank you for your help.
Lennart
Re: Observations and AR model
Postby startz » Sat Aug 28, 2010 1:25 pm
AR(1) needs one lagged observation. You're probably missing that for some variables. Set the smpl to reflect complete observations for all dependent and independent including accounting for the lag. As a guess, just exclude the first observation in your current smpl.
lentjeuhz
Postby lentjeuhz » Sun Aug 29, 2010 2:08 am
Hi startz,
Thanks for your help.
That's what I thought as well, therefore I added the following selection criteria to my sample criteria when estimating to ensure that only complete observations are used:
sample: 1998 - 2009 if var1 <> na and var2 <> na ... etc
But it seems that this method doesn't include these selection criteria for the lagged variables needed for the AR(1) process.
Any ideas?
lentjeuhz
Postby lentjeuhz » Sun Aug 29, 2010 2:23 am
I have solved the problem by generating new series for my dependent variables, setting them equal to NA if one of the other dependent variables is NA as well.
