is vertical alignment possible in addtext?
javiersan
Postby javiersan » Thu Aug 12, 2010 9:27 am
Is there a way for the text in addtext to be displayed like in the attached image?
Thanks,
Javier
Re: is vertical alignment possible in addtext?
Postby EViews Gareth » Thu Aug 12, 2010 9:31 am
I do not believe so.
Postby startz » Thu Aug 12, 2010 10:38 am
Would you get what you need by position Left-rotated and then dragging it where you want it by hand?
javiersan
Postby javiersan » Thu Aug 12, 2010 10:50 am
It is a good suggestion thanks but I intend to do several dozens graphs with a program and then automatically save them to disk so it would not work.
Thanks,
Javier
EViews Pamela
Postby EViews Pamela » Thu Aug 12, 2010 11:18 am
Yes, adding the text to the left and dragging would be the work-around to achieve this. But you're correct, this will only work with dragging.
