Is possible to get the code from what EVIEWS does?
PERRYGOGAS
Postby PERRYGOGAS » Thu Dec 25, 2008 6:55 pm
Lets say I estimate a GARCH(p,q)-M model using EVIEWS's menus. Is it possible after the estimation
to get from somewhere in EVIEWS the actual program that was run by it? I mean doing the same estimation
with inputing a program instead of using menus.
The reason is to be able to alter the program where it seems appropriate...
Re: Is possible to get the code from what EVIEWS does?
Postby EViews Gareth » Thu Dec 25, 2008 8:38 pm
In general you cannot record point and click actions into programming code in EViews. However with most equation and system estimations you can click on View->Representations to get the command form.
