Replacement variable to replace various strings in loop
raphbrun
Postby raphbrun » Fri Jul 09, 2010 3:37 pm
I have a program where the same loop is coming at various occasions:
for %y fr us uk
If I then need to change my loop, e.g. replace "for %y fr us uk" by "for %y fr us", I will have to do so every time the loop is coming in the program. Ideally, I would like to make only one change and see this change reflected in all the loops. I am thinking of replacing the content of the loop by a replacement variable to be defined at the start of the program but the way I do it does not work:
%loop = "%y " + "fr " + "us " + "uk"
for %loop
scalar s_{%y}=1
The following does not work neither:
for {%loop}
scalar s_{%y}=1
I guess this is an important question while programing. Any idea?
Re: Replacement variable to replace various strings in loop
Postby EViews Gareth » Fri Jul 09, 2010 4:16 pm
%loop = "fr " + "us " + "uk" for %y {%loop} scalar s_{%y}=1 next
raphbrun
Postby raphbrun » Mon Jul 12, 2010 10:57 am
Your reply makes sense and must be correct but I guess it is only be valid on later versions of Eviews. I have tried it on Eviews 5 and it does not work.I am aware Eviews 7 has made progress with strings and I suppose your code must be working on the latest version.
Thanks again
Postby EViews Glenn » Mon Jul 12, 2010 11:23 am
The replacement of the loop strings is a version 7 feature.
