robust wald test
pat123123
robust wald test
Postby pat123123 » Thu Jul 01, 2010 2:46 pm
I am using Eviews 6. I want to know whether the programmed Wald test of a subset of coefficients is valid if using Newey-West robust estimation. The User's Guide seems to suggest otherwise, but I read a forum discussion that seemed to indicate that the Wald test is also robust. If it is not robust in Eviews 6, is it robust in Eviews 7. Thanks.
Re: robust wald test
Postby EViews Gareth » Thu Jul 01, 2010 2:58 pm
The Wald test in EViews uses the equation's estimated standard errors. Thus if you estimate the equation using robust standard errors, then those will be used by the Wald test.
pat123123
Postby pat123123 » Sat Jul 03, 2010 8:23 am
thanks for you reply
