lagged difference terms
gauvain
Postby gauvain » Mon May 10, 2010 8:16 am
this is part of my program to determine the optimal lag length.
for !i=1 to l for !j=1 to m equation {%retail}_!i_!j.ls d({%retail}) resid_{%retail}(-1) c d(ffo(-1 to -!i)) d({%retail}(-1 to -!j)) next
Everything works fine using a model without differences. However when I try to use differences for ffo and %retail Eviews 6 tells me: "-1TO-1 is not a valid index for ffo"...
How can I use differences in this loop?
Thank you for your help!
Re: lagged difference terms
Postby EViews Gareth » Mon May 10, 2010 8:48 am
Unfortunately you cannot use the (-i to -j) syntax on an autoseries such as the D( ) operator. You'll have to write out the expression fully.
