Graph of irregular dated workfile series
lzg_jlu
Postby lzg_jlu » Fri May 07, 2010 6:53 am
Dear all,
I created a new workfile by wfopen a excel file which contains some stocks trading data(see attachment). The workfile generated (see attachment) is irregular dated structured, then I made a line graph of a series, but the line was not continuous because of "sample breaks and Na handing" in this irregular dated workfile. To get a continuous line I selected the "connect adjacent" option under "sample breaks and Na handing" on graph option window by hand. Can Anybody tell me how to get continuous line by command under this irregular dated structure?
Thanks.
Liu
stock.wf1
workfile by open foreign data as workfile
(12.41 KiB) Downloaded 274 times
stock.xls
source data file
(20.5 KiB) Downloaded 322 times
Re: Graph of irregular dated workfile series
Postby EViews Gareth » Fri May 07, 2010 8:09 am
graph.options connect
Where graph is the name of your graph object.
lzg_jlu
Postby lzg_jlu » Fri May 07, 2010 5:20 pm
It works well, thank you Gareth.
But I failed to find this usage in command reference file, Where can I get the graph options specification help?
