alpha series and cross-sectional data
deroekonom
Postby deroekonom » Thu Dec 11, 2008 3:05 am
hello,
I imported data from excel with three different observations for 25 regions.
However, I also have to import data where the 25 regions are cross-sectional linked. I.e there are two 25x25 matricices which I want to import into eviews too.
But I'am not sure how to do that. Maybe somebody can help me. I'am not sure but maybe the solution is to define cross-section
identifiers?
Thx for help.
doe
deroekonom
Re: alpha series and cross-sectional data
Postby deroekonom » Thu Dec 11, 2008 3:08 am
hello again,
I forgot to mention that one of the 25x25 matrices may be generated by one of the values assigned to the regions.
However, the second matrix has nothing to do with the values already assigned to the regions. The second matrix consists of values which are exogenously given.
Thx.
Postby EViews Gareth » Thu Dec 11, 2008 9:34 am
I've read our posts a couple of times, but I'm having a real problem understanding what you're trying to do :(
deroekonom
Postby deroekonom » Fri Dec 12, 2008 2:53 am
hello,
I'am sorry if I confused you.
My meaning was:
I have vales for every region in my sample, e.g.:
Florida: 25
New York: 50
California: 100
Now I want to have a matrix which shows the ratios of all the regions in comparion to all other regions; something like that:
Florida New York California
Florida 1 0.5 0.25
New York 2 1 0.5
California 4 2 1
I don't know how to do get that matrix in eviews.
Thx your help.
Postby EViews Gareth » Fri Dec 12, 2008 10:05 am
No easy way to do it, but with a little bit of work you can create it:
(note in this example I am first creating a dataset with your 3 datapoints. You could expand the matrix creation bit to work on your fuller dataset).
'create data create u 3 series values smpl 1 1 values = 25 smpl 2 2 values = 50 smpl 3 3 values = 100 smpl @all 'calculate matrix matrix out = @outer(values,values) vector(3) ones = 1 matrix denom = @outer(values,ones) denom = @emult(denom,denom) matrix results = @ediv(out,denom) d out denom ones
