Hello
I am looking for a way to save the stats of a sample in a row-vector instead of displaying them.
I just need the basic statistic characteristics e.g. mean, sd, skewness, kurtosis, Jarque-Bera, p-value JB, min and max.
I am using EViews 6.
Thank you for any help!
Save the stats?
Re: Save the stats?
Your question isn't quite well defined.
Which object are you trying to save the stats of?
Re: Save the stats?
Hello
Sorry for that. I have a vector with return data of a stock index. I introduced a rolling window which is moving through that data. I tried to save the descriptive statistics. I found that out in the meanwhile... just using e.g. @mean(returns) gives me the return etc.
But now I am looking for a way to get the autocorrelations of different lags and their significance (like one gets if he looks at the correlogram ).
Is there a chance to do that in EV6?
Thank you.
Thank you.
EfficientMarketeer
Re: Save the stats?
Hi There,
Very new to all this, and I'm trying to do what the OP was trying to do initially, i.e. save descriptive stats (specifically Jarque-Bera) in a series from a rolling window program. I've got the rolling window bit sorted but I'm having trouble saving the stats. How can I do this?
Many thanks,
EM
Many thanks,
EM
Re: Save the stats?
Freeze the stats view into a table, then grab it from that:
http://forums.eviews.com/viewtopic.php? ... 8&p=18#p18
EfficientMarketeer
Re: Save the stats?
Still not getting it I'm afraid. If I start with the following it runs the rolling stats program with no problems, but obviously doesn't store anything for me:
However, if I try to add freeze commands etc, as suggested above and in the link provided, it doesn't work. Can anyone crack the code for me?
Much appreciated,
EM
for !horizon=1 to 1000
smpl 0+!horizon 1674+!horizon
dlftse.stats
Much appreciated,
EM
EfficientMarketeer
Re: Save the stats?
Finally figured it out! Thanks again for the help.
EM
freeze(mytab) dlftse.stats
!jb = mytab(14,2)
d mytab
