Structural VAR (EV 6)
Posted: Wed Apr 28, 2010 2:57 pm
Hi there,
I'm getting an error message when running the code. Checking out help, I probably misunderstand the SVAR estimation command... The code builds up on VAR model estimated and saved in this workfile in a previous session. Could that be a problem, that one needs to estimate the VAR model and continue with the structural factorization immediately in one and the same session?
Many thanks for helping!!!
var02.makeresids rev_var02res xpe_var02res gdp_var02res
':: compute cyclically adjusted fiscal policy
series ca_rev
ca_rev = rev_var02res - a1(2) * gdp_var02res
series ca_xpe
ca_xpe = xpe_var02res - a1(2) * gdp_var02res
':: declare coefficient vectors
coef(2) c1
coef(2) c2
coef(2) b2
':: estimate set of least squares equations
equation eq_c1_rev.ls gdp_var02res = c1(1) + c1( 2) * ca_rev
equation eq_c2_xpe.ls gdp_var02res = c2(1) + c2( 2) * ca_xpe
equation eq_b2_xpe.ls ca_xpe = b2(1) + b2(2) * ca_rev
':: put together the left and right hand side matrix as in B&P (2002)
matrix(3,3) left
left.fill(b=r) 1, 0, -a1(2), 0, 1, -b1(2), -c1(2), -c2(2), 1
matrix(3,3) right
right.fill(b=r) 1, 0, 0, b2(2), 1, 0, 0, 0, 1
':: estimate structural factorization using the short run matrices left, right
var02.svar(rtype=patsr,namea=left,nameb=right)
