Structural VAR (EV 6)
nadja123
Postby nadja123 » Wed Apr 28, 2010 2:57 pm
Hi there,
I'm getting an error message when running the code. Checking out help, I probably misunderstand the SVAR estimation command... The code builds up on VAR model estimated and saved in this workfile in a previous session. Could that be a problem, that one needs to estimate the VAR model and continue with the structural factorization immediately in one and the same session?
Many thanks for helping!!!
var02.makeresids rev_var02res xpe_var02res gdp_var02res ':: compute cyclically adjusted fiscal policy series ca_rev ca_rev = rev_var02res - a1(2) * gdp_var02res series ca_xpe ca_xpe = xpe_var02res - a1(2) * gdp_var02res ':: declare coefficient vectors coef(2) c1 coef(2) c2 coef(2) b2 ':: estimate set of least squares equations equation eq_c1_rev.ls gdp_var02res = c1(1) + c1( 2) * ca_rev equation eq_c2_xpe.ls gdp_var02res = c2(1) + c2( 2) * ca_xpe equation eq_b2_xpe.ls ca_xpe = b2(1) + b2(2) * ca_rev ':: put together the left and right hand side matrix as in B&P (2002) matrix(3,3) left left.fill(b=r) 1, 0, -a1(2), 0, 1, -b1(2), -c1(2), -c2(2), 1 matrix(3,3) right right.fill(b=r) 1, 0, 0, b2(2), 1, 0, 0, 0, 1 ':: estimate structural factorization using the short run matrices left, right var02.svar(rtype=patsr,namea=left,nameb=right)
country1.wf1
(21.97 KiB) Downloaded 447 times
Re: Structural VAR (EV 6)
Postby EViews Gareth » Wed Apr 28, 2010 3:39 pm
Your SVAR doesn't have any parameters to estimate. Both of your matrices (left and right) have been completely filled with values. As explained in the User Guide, you need to use NAs to define which elements are to be estimated.
nadja123
Postby nadja123 » Thu Apr 29, 2010 1:37 am
Hi QMS Gareth,
thanks for reply. In the code I did not take into account that Structural factorization is strictly an estimation procedure. What I need in this case is rather imposing a specific indentification scheme to come up with structural shocks. The matrices left and right together build the transformation (or projection) matrix which should be used instead of a cholesky factor etc.
My questions:
1. Now I am not sure whether using own transformation matrix for computation of impulse responses is possible in EViews and how to do it?
I doubt that this could be done under Impulse: User specified. By the way from the help documentation it is not completely clear to me, which underlying transformation matrix is used for User specified impulses. Or maybe I just understand it wrongly.
2. Should I try to write a code to compute such impulse responses "by hand"? [I am facing a similar problem with an attempt to impose a combination of short and long run patterns.]
Thanks for helping, it is really urgent for me.
