Var command (EV 6)
nadja123
Var command (EV 6)
Postby nadja123 » Thu Apr 22, 2010 8:01 am
Hi there,
I would be grateful for helping with this: I want to run the same set of commands upon multiple workfiles (below I give just a fragment).
for !j = 1 to 2 open C:\Zeviewsdirectory\country{!j}.wf1 open C:\Zeviewsdirectory\copiescharts.wf1 var var01.ls 1 3 gdp rev xpe freeze(gdp_gdp_grx_{!j}) var01.impulse(20, se=a) gdp @ rev @ gdp rev xpe copy gdp_gdp_grx_{!j} copiescharts:: save C:\Zeviewsdirectory\country{!j}.wf1 close country{!j} next save C:\Zeviewsdirectory\copiescharts.wf close copiescharts
Running the code gets stuck at the fourth line
with the error message: GDP is not defined for var var01....
What is strange, if I open the country1.wf1 or country2.wf1 and run the fourth line in interactive mode, it just produces the estimate. I am sorry, maybe I am too overworked. I attach the workfiles. Many thanks for a rescue!!!
copiescharts.WF1
(7.28 KiB) Downloaded 367 times
country2.wf1
(9.11 KiB) Downloaded 344 times
country1.wf1
(9.11 KiB) Downloaded 338 times
Re: Var command (EV 6)
Postby EViews Gareth » Thu Apr 22, 2010 8:05 am
The third line tells EViews to open "copiescharts.wf1". Thus you are no longer working with the country workfile. Thus GDP can't be found.
