How to get F-stat in GARCH/ARCH estimation?
debasishmaitra
Postby debasishmaitra » Tue Apr 20, 2010 8:36 am
Please somebody help me in getting the F-stat of GARCH estimation in Eviews-7?
Its not coming in output table..
Re: How to get F-stat in GARCH/ARCH estimation?
Postby EViews Gareth » Tue Apr 20, 2010 10:32 am
We dropped it from the output, since we felt it wasn't being calculated properly.
EViews 6 would compute the F-statistic by comparing the estimated equation against a constant only (i.e. no GARCH/ARCH terms) model, when in fact what you really want to do is compare it to the no-regressors (other than constant) model which has GARCH/ARCH terms. Since this would require re-estimating a model, it was decided to simply drop the F-stat.
fmgoto
Postby fmgoto » Tue Apr 20, 2010 11:17 am
Gareth, I have used the code below for calculating the probability of F. Although it is a good approximation, it is quite often different from the F calculated by Eviews.
Could you provide the formula Eviews uses for calculating it? Which is more accurate?
Thank You, Fabio
scalar f_p_value = 1 - @cfdist(eq01.@f, eq01.@ncoef-1, eq01.@regobs-eq01.@ncoef)
Postby EViews Gareth » Tue Apr 20, 2010 11:33 am
That's exactly how it is calculated. Could you provide an example of it not matching?
fmgoto
Postby fmgoto » Tue Apr 20, 2010 2:18 pm
I have been running this code for a while and some times I get two different values. But I dont get an example right nwo. I ll try to remember posting it next time I get it. Probably my mistake. Thanks.
debasishmaitra
Postby debasishmaitra » Tue Apr 20, 2010 10:00 pm
Many Many Thanks Gareth and Fmgoto for your prompt reply..
Thanks a ton..\
But Gareth and Fmgoto can you tell me how to put this code to get F-stat? I mean where to write it..?? If you can give a protocol to do this...
Rosa.hh
Postby Rosa.hh » Tue Jan 25, 2011 9:56 am
Hi.
I'm trying to calculate the F-stat in an EGARCH estimation using the code above however it is not working for me when using the specification below.
Any idea of what should I do to calculate the F-stat using an EGARCH model? I enclose my database
Thanks a lot,
equation eq01.arch(1,1,egarch,m=1000,h) dlner c dlner(-1 to -1) i_diff(0 to 0) BOG_APR BOG_NET BOG_DEP mon tue wed thu @ BOG_APR BOG_NET BOG_DEP mon tue wed thu
basefile.WF1
(295.01 KiB) Downloaded 788 times
Postby EViews Gareth » Tue Jan 25, 2011 10:10 am
As mentioned above, EViews 7 does not calculate the F stat for GARCH/ARCH models.
Rosa.hh
Postby Rosa.hh » Tue Jan 25, 2011 10:22 am
Thanks for the quick response Gareth. Is there any alternative to applying a joint significance test in EGARCH estimations? Is it possible to calculate it from scratch using the F-test formula [ (RSS1-RSS2/P2-P1)/RSS2/N-P2] ?
