PNG graph.save(t=png,d=300) exports at ~96 DPI metadata, not 300 DPI
ikarib
Postby ikarib » Tue May 19, 2026 9:45 am
Hi EViews team,
I think there may be a bug in PNG export DPI metadata.
I exported graphs with commands like:
rer_trends.save(t=png,d=300) "RER_trends.png" rer_irf.save(t=png,d=300,w=8,h=5) "RER_IRF.png"
The program runs successfully and the PNG files are created, but the resulting files do not appear to be tagged as 300 DPI. Both files are 96 DPI.
The pixel dimensions are large enough, so d=300 may be affecting export sizing, but the PNG resolution metadata/pHYs chunk is still written as ~96 DPI. This causes automated checks and downstream publishing workflows that inspect DPI metadata to fail.
Expected behavior: save(t=png,d=300) should produce a PNG whose horizontal and vertical DPI metadata are 300.
Can you confirm whether d=300 is intended to set PNG DPI metadata, and if so whether this is a known issue?
Thanks.
EViews Matt
Re: PNG graph.save(t=png,d=300) exports at ~96 DPI metadata, not 300 DPI
Postby EViews Matt » Mon Jun 01, 2026 4:23 pm
You're correct that the DPI information wasn't being recorded correctly. The next patch to EViews 14 will include a fix for this issue.
