@makedate and weeks - unexpected error
mamo
Postby mamo » Thu Sep 04, 2025 1:54 am
Hi, using Eviews 14 Dec 2024 build.
What is wrong with the following command line? Unexpectedly, it produces the error message "Bad date format 'yyyyww' - Missing data generated."
series x=@makedate(201143, "yyyyww")
Re: @makedate and weeks - unexpected error
Postby EViews Gareth » Thu Sep 04, 2025 10:31 am
makedate doesn't support weeks [because a week doesn't identify a date]
mamo
Postby mamo » Fri Sep 05, 2025 1:00 am
Well, the functions @dateval and @datepart(@date, week) obviously assign 1) a date to a specified week and 2) a week to a specified date, respectively. So there seems to be a uniquely defined link between weeks and dates (as is also the case with months and dates).
So suggestion here. Please make @makedate work also applicable to weeks in future updates of Eviews.
wfcreate w 2000 2010 show @dateval("2008W33", "yyyy[W]ww") show @date @datepart(@date, "WW")
Postby EViews Gareth » Fri Sep 05, 2025 7:50 am
Those two functions are series functions, and so are able to use workfile context to determine the dates that correspond to the weeks (and vice versa). If you create a monthly workfile instead of a weekly workfile, you'll notice that @dateval fails.
@makedate is not a series function and so does not use workfile context.
mamo
Postby mamo » Mon Sep 08, 2025 2:37 am
Hm, @dateval works fine and as expected with a monthly date as argument in any workfile context.
There seems to be an issue with calendar-week dates in Eviews.
wfcreate m 2000M01 2010M12 show @dateval("2009M04", "yyyy[M]mm")
wfcreate u 1 show @dateval("2009M04", "yyyy[M]mm")
Postby EViews Gareth » Mon Sep 08, 2025 7:23 am
Right, because months are always defined. Weeks are not a defined concept. There is no defined "Week 1" of a year. That entirely depends on whatever structure the user is using. But January is always the first month of the year.
mamo
Postby mamo » Thu Sep 11, 2025 12:05 am
So here is a workaround for @makedate with years & weeks as arguments not working:
Assume you have an unordered workfile containing variables indicating year and week of the year, "year" and "week", respectively. In order to generate a proper date series "date" out of "year" and "week" you may use the following command line:
series date=@dateadd(@makedate(year, "yyyy"), week-1, "WW")
See example code below
Best, mamo
' Create an unordered workfile containing the variables "year" and "week" wfcreate u 20 series year = 2000+@trend series week = NA rndint(week, 51) week=week+1 sort year week ' create a date series using the variables "year" and "week" series date=@dateadd(@makedate(year, "yyyy"), week-1, "WW") ' crosscheck group gr @datepart(date, "WW") week gr.sheet(c)
Postby EViews Gareth » Thu Sep 11, 2025 8:18 am
Whether that will give you what you want or not, depends on how you are defining weeks.
