Problem with coint command
Posted: Fri Apr 11, 2025 4:00 am
Problem with coint command. The enclosed program writes the results from the coint-command into a spool object (line 85). Which works when no number of lags is given (i.e. coint(s)). Writing the results into the spool object fails when the number of lags is given by an information criterion as in line 84 which is commented out. (in this case !p=3). The error message is
Invalid specification of number of cointegrating equations i
n "PRINT INDICATORS.COINT(S,3)" in COINT_PROG.PRG on line
84.
Enclosed find the program file coint_prog.prg and the corresponding data file coint_data.wf1.
Can someone help me to solve the problem.
Fritz
84.
Fritz
