Problem with coint command
fritz_austria
Postby fritz_austria » Fri Apr 11, 2025 4:00 am
Problem with coint command. The enclosed program writes the results from the coint-command into a spool object (line 85). Which works when no number of lags is given (i.e. coint(s)). Writing the results into the spool object fails when the number of lags is given by an information criterion as in line 84 which is commented out. (in this case !p=3). The error message is
Invalid specification of number of cointegrating equations i
n "PRINT INDICATORS.COINT(S,3)" in COINT_PROG.PRG on line
84.
Enclosed find the program file coint_prog.prg and the corresponding data file coint_data.wf1.
Can someone help me to solve the problem.
Fritz
coint_prog.prg
(18.44 KiB) Downloaded 11539 times
coint_data.wf1
(25.93 KiB) Downloaded 10847 times
Re: Problem with coint command
Postby EViews Gareth » Fri Apr 11, 2025 8:48 am
Not entirely sure I follow, but if you want to specify the lags for the Johansen test, it is an argument, not an option:
indicators.coint(s) 1 !p
fritz_austria
Postby fritz_austria » Sun Apr 13, 2025 11:24 pm
Thank you. This works.
However, I find it confusing that the lag specification is an option when the series are specified after the coint command while the lags are a parameter in case the series are a group followed by the coint command.
Fritz
