Issue with equations in input box
kubajj
Postby kubajj » Wed Apr 09, 2025 6:56 am
Hi All,
I am lately having an issue in where I enter an equation in the input box, say:
Y c X1_L2L2 X2_L2L2 X3_L2L2
and then run this equation, receiving the output associated with the above.
However, when I click estimate to update the above, the input box reverts to a prior equation, let's say:
Y c X1_L1L1 X2_L1L1 X3_L1L1
This is essence means that I have to retype the equation that I wanted to estimate and then change it to what I want it to be.
As you can imagine, this is very inconvenient if one is tweaking equations.
This started happening in Eviews 14 and also happens in Eviews 14 and in four different project files.
Any ideas what is causing this or a fix?
Re: Issue with equations in input box
Postby EViews Gareth » Wed Apr 09, 2025 8:42 am
I cannot replicate this. Can you provide an example file, or steps to replicate?
kubajj
Postby kubajj » Thu Apr 10, 2025 2:44 am
I sent a screen recording with the issue.
Regards.
Postby EViews Gareth » Thu Apr 10, 2025 7:58 am
What's the build date of your copy of EViews 14? (Help->About EViews)
kubajj
Postby kubajj » Thu Apr 10, 2025 9:21 am
This is happening with both Eviews 13 and 14.
For Eviews 13: Feb 6 2025 build
For Eviews 14: April 8 2025 build.
This has never happened before and I have been using Eviews for a while - these and earlier versions.
Postby EViews Gareth » Thu Apr 10, 2025 10:54 am
It is possibly related to your specific file. Could you post your workfile?
kubajj
Postby kubajj » Fri Apr 11, 2025 2:23 am
I shall send these to you in a DM.
Please note that this is across four files.
kubajj
Postby kubajj » Thu Apr 17, 2025 3:02 am
Sent via private message.
Postby EViews Gareth » Sat Apr 19, 2025 7:12 pm
How was the equation generated?
