Illegal date when importing txt file
patrice
Postby patrice » Tue Feb 11, 2025 8:56 am
When trying to import this txt file, I have this error message: Illegal date ?.
Here my code:
wfcreate m 2010 2025 import(type=txt, resize) "c:\temp\eviews_issue.txt" ftype=ascii rectype=crlf skip=0 fieldtype=delimited custom=";" colhead=1 namepos=custom eoltype=pad badfield=NA @smpl @all
If I remove the last row, it's working fine.
I tested this under all these version, with same bug:
- Eviews 13 Jun 20 2024 build
- Eviews 14 Dec 26 2024 build
Thanks for your help.
Re: Illegal date when importing txt file
Postby startz » Tue Feb 11, 2025 9:06 am
If you could post that last row in the text file there's better chance someone might catch what's wrong.
patrice
Postby patrice » Tue Feb 11, 2025 9:19 am
The attached txt file in the ticket contains this row, I have the error message using this txt file.
eviews_issue.txt
(3.47 MiB) Downloaded 24837 times
Postby startz » Tue Feb 11, 2025 9:30 am
If it helps, I get the same error you do. But if I use File/Open it appears to work. No idea why.
patrice
Postby patrice » Tue Feb 11, 2025 12:00 pm
Thanks, but unfortunatly I'm using this in an eviews program.
Postby EViews Gareth » Tue Feb 11, 2025 7:17 pm
You're trying to import panel data (I think?) into a dated workfile, and it is failing.
Rather than create the workfile and then import, just open the text file as a new workfile.
wfopen "c:\temp\eviews_issue.txt" ftype=ascii rectype=crlf skip=0 fieldtype=delimited custom=";" colhead=1 namepos=custom eoltype=pad badfield=NA @smpl @all
Then manipulate it after opening.
Postby startz » Tue Feb 11, 2025 7:25 pm
Some of the dates look like 201001. Is there a good way to handle that?
patrice
Postby patrice » Wed Feb 12, 2025 12:30 am
Thanks for this, but do-you know why there is this error message ? is-it a eviews bug ? (It's not an easy task to change my program)
Postby EViews Gareth » Wed Feb 12, 2025 8:25 am
The last line of your file has no date.
