I have a workfile with hundreds of objectives (graphs, equations, tables, etc). Is there a command (or line of code) I can run to open a certain object instead of having to look through the workfile each time?
How to find or check if an object is available/exists in a workfile?
Re: How to find or check if an object is available/exists in a workfile?
Just select the correct workfile page (if there are multiple), then type in:
to display the X object. If you type this into the Command window, you should see a dropdown after typing the first letter of the object name so you can pick from matching names.
Help page: show
To test if an object exists, use @isobject
show xto display the X object. If you type this into the Command window, you should see a dropdown after typing the first letter of the object name so you can pick from matching names.
Help page: show
It works, thank you!
Hi Gareth,
Just another question - how do you quickly check to see if a list of objects with the same first few letters exist in your work file? For example, is there a quick way to see if any objects that start with "Varxy..." exist in my workfile?
Thank you.
Thank you.
Thank you, this helps massively!
