qreg estimation and forecast
ndzama
Postby ndzama » Sat Nov 16, 2024 10:44 am
Dear EViews experts,
I am trying to estimate the quantile regression and generate forecasts for my y-variable.
I am using quarterly data covering the period from 1980Q1 to 2023Q4. However, I keep encountering an error related to "missing data." This appears to be linked to the "sample range pairs" setting, which I suspect might be due to a coding oversight. I’ve attached the relevant error code.
My code can estimate and solve the model, and generate forecast errors. However, I am encountering this error along the way, which I really don't understand why.
Please assist.
Kind Regards,
Nwabisa
SA_QUARTERELY DATA.xls
(191 KiB) Downloaded 21761 times
qreg_7 nov 2024.prg
(24.28 KiB) Downloaded 21551 times
qreg_missing data error.PNG (111.83 KiB) Viewed 31815 times
Re: qreg estimation and forecast
Postby EViews Gareth » Sat Nov 16, 2024 12:54 pm
You have a single endogenous variable. 3 exogenous variables. The endogenous variable is a function of the exogenous is current period only. To forecast a value of the endogenous variable, you need data for the exogenous.
As you say, there's probably an issue with the sample you're setting.
