Speed up model.control proc
gmcatee
Postby gmcatee » Fri Nov 01, 2024 2:05 pm
This post is long overdue, but when I upgraded from EViews 8.1 to EViews 12, I noticed that the model.control procedure was taking much longer to complete. Is there a difference in how the two versions perform this procedure? Are there any settings I can change to speed up the calculation?
I've constructed an example from the Fair Model (workfile attached).
Running the following code in EV8 takes about 5 seconds but takes almost 24 seconds in EV12
tic for !repeat = 1 to 20 for %v CD CN CS CUR DF HF HO IHH IM INTG JF KK L1 L2 L3 LM MF PF RB RM RS WF Y fma_ev.control {%v}_a {%v} {%v} next next !time = @toc show !time
usev242.wf1
(1.41 MiB) Downloaded 22747 times
Re: Speed up model.control proc
Postby EViews Gareth » Fri Nov 01, 2024 2:24 pm
I’m afraid the control proc has undergone many revisions since EViews12, so you’re unlikely to get much feedback on such an old version.
gmcatee
Postby gmcatee » Fri Nov 01, 2024 2:40 pm
Understood. It sounds like there are no options that can be adjusted by the user -- is that right?
I am curious though -- are you able to run the code with this workfile in EV14 to see how long it takes there? I get similar results using a 7-year-old laptop and a brand new one, so the system specs shouldn't make a difference. We use this function hundreds of times when updating the forecast, so the few seconds difference adds up.
Postby EViews Gareth » Fri Nov 01, 2024 3:01 pm
16 seconds.
gmcatee
Postby gmcatee » Fri Nov 01, 2024 4:19 pm
Got it, thanks. If you stumble on anything that might make this run faster please let me know. For now, we're clinging on to EV8 for this part of our process
Postby tvonbrasch » Sat Nov 02, 2024 10:14 am
It’s not a perfect solution, but rewriting the equation might help, i.e. from "equation" to "-x_a+equation" and then solve for x_a. See the details below and in the attachment. This adjustment reduces the execution time from 25 seconds to 8 seconds.
t
' '-------------------------------------------------------------------- !i=!i+1 %mn=%m+%v %mn=@getnextname(%mn) copy {%m} {%mn} {%mn}.scenario(n,alias="_zer") zero %equation="eq??_"+%v %equation=@wflookup(%equation, "equation") %subst={%equation}.@subst %add=%v+"_a" %subst0 = "-"+%add+"+"+%subst {%mn}.drop {%v} {%mn}.append {%subst0} {%mn}.solve copy(o) {%add}_zer {%add} delete {%mn} *_zer '--------------------------------------------------------------------
control_rewrite_equation.prg
(857 Bytes) Downloaded 22835 times
gmcatee
Postby gmcatee » Mon Nov 04, 2024 7:12 am
Thanks Thomas - I'll give this a try when I have some down time this week
EViews Matt
Postby EViews Matt » Mon Nov 04, 2024 5:47 pm
Elaborating on Gareth's response, there was a major update to the Model::control procedure in EView 12 when we introduced the ability for multivariate controls. While I'd describe the new algorithm as numerically superior overall, it can be more computationally intensive even in the univariate case. If you absolutely can't afford the resulting extra time, it's still possible to use the old pre-EViews 12 univariate control algorithm by adding the "legacy" option to the control procedure, e.g.
fma_ev.control(legacy) {%v}_a {%v} {%v}
gmcatee
Postby gmcatee » Wed Nov 06, 2024 12:28 pm
Great, thanks for the tip Matt - that works for my application
Return to “Models”
