DID models for non-panel data
miharbi
Postby miharbi » Sun Jul 28, 2024 3:49 pm
Hi everyone,
I found in the EViews Help this statement: (To estimate DID models on non-panel workfiles, you will need to specify the appropriate least squares model manually using standard least squares regression.)
What does this statement mean, especially for non-panel data structures? I hope to find a practical example of this point?
Re: DID models for non-panel data
Postby EViews Gareth » Sun Jul 28, 2024 4:22 pm
Difference in Difference estimation is just standard OLS. EViews doesn't have a built in DiD estimator for non-panel workfiles, but since it is just OLS, you can estimate it with the OLS estimator.
miharbi
Postby miharbi » Mon Jul 29, 2024 5:02 pm
Thank you Gareth for your response!
I have no problem with what you said, but I want to understand the structure of non-panel data. What do you mean by it? Is there a practical example or a paper that has addressed this?
Postby startz » Wed Jul 31, 2024 9:24 am
Suppose you have an outcome variable y and two dummy variables, treated and after. (So some observations of y are treated after a certain date and others are never treated--the control group.) You could do
ls y c treated after treated*after
The last coefficient is the DiD estimate.
miharbi
Postby miharbi » Fri Aug 02, 2024 12:08 pm
Thank you Starz,
It's very clear now.
