Eviews crash on pageload
yguill1
Postby yguill1 » Fri Mar 01, 2024 5:31 am
Eviews crashes/disappears with no error message with these instructions and the attached Access database:
wfcreate a 2010 2020
pageload(type=access) Database1.accdb "select TEST from MY_TABLE" @freq U 1 @smpl @all
Note that we encounter this problem accessing a SQL database but our IT specialist was able to reproduce it using an Access database.
Note also that this issue began with Eviews 13 December 19 build. With previous builds, or Eviews 12, the issue does not occur. We have not yet installed the very latest build so unable to test if the issue is still present.
Database1.zip
Zipped Access database
(17.32 KiB) Downloaded 21982 times
Re: Eviews crash on pageload
Postby EViews Steve » Fri Mar 01, 2024 10:46 am
I can confirm the crash in Dec 19 build, but it seems to be fixed in latest Jan 8 build.
yguill1
Postby yguill1 » Mon Mar 04, 2024 2:30 am
Thank you for the quick reply!
