Dummy variable UP/Down
Posted: Mon Jul 24, 2023 8:01 am
by Sima77
Hi, I have multiple time series of stock returns, I want to create dummy variables that are 1 when the return increase and 0 when the return decrease. The problem am facing when the returns is the same for several months. For instance, the returns for the following 7 months are 3,4,2,5,5,5,5, I want the dummy variable to be 1 for the last 4 months and not only for the fourth month. Please I would appreciate any help.
Re: Dummy variable UP/Down
Posted: Mon Jul 24, 2023 8:15 am
When you create your dummy variable, instead of using ">", use ">=" instead.
Posted: Mon Jul 24, 2023 8:41 am
by Sima77
Thanks for reply. I used this command: series dummy=@recode(y>=y(-1),1,0), but I still have the same problem.Please can you advice?
Posted: Mon Jul 24, 2023 9:00 am
It works.
wfcreate u 7 series y y.fill 3,4,2,5,5,5,5 series dummy = @recode(y>=y(-1),1,0) show dummy
Posted: Mon Jul 24, 2023 9:56 am
by Sima77
Sorry, It is my bad that I did not well explain what I want to do. I attached an Excel file in which I typed the Dummy that I want. Please can you help which code can do that? Much appreciated,
Posted: Tue Jul 25, 2023 6:57 am
by Sima77
I would appreciate it if I get a reply to my question.
Posted: Tue Jul 25, 2023 7:02 am
Gareth's suggestion does what you ask. In your file you have the dummy stay zero if the return stays constant after it first falls. Is that what you want?
Posted: Tue Jul 25, 2023 8:35 am
by Sima77
Yes, I want the dummy to stay constant (0 or 1) if the return stays constant. Please can you help?
Posted: Tue Jul 25, 2023 1:13 pm
by EViews Matt
Building on Gareth's example, a self-referential expression lets you maintain the previous dummy value in the case that the return is constant.
series dummy = @recode(y>y(-1),1,@recode(y<y(-1),0,@nan(dummy(-1),1)))
Posted: Wed Jul 26, 2023 10:41 am
by Sima77
Amazing, this is exactly what I want. Thanks.
