EIA v2 API not working
Posted: Mon May 01, 2023 12:32 pm
by dman
Hello.
I'm trying to pull some data via the recently-added EIA v2 API.
I can select the variables via browsing the DB (STEO - PAIMPORT), but the 'export to workfile' fails with '404 not found error.'
Please look into it asap.
Thanks!
Re: EIA v2 API not working
Posted: Mon May 01, 2023 3:53 pm
by EViews Steve
Fix will be in the next 13 patch.
You can manually download the fix here if you'd like to test it before then.
Posted: Mon May 01, 2023 8:59 pm
by dman
Thanks!
I tested the fix.
Monthly and annual frequency requests seem to work.
Quarterly requests fail with the error pictured in the attachement.
But I can work around those.
Thanks again.
Posted: Tue May 02, 2023 7:46 am
by EViews Steve
Quarterly problem has been fixed and will be available in next 13 patch.
