BVAR IRFs and Cholesky ordering
bcfc82
Postby bcfc82 » Thu Apr 13, 2023 4:06 am
Hi, I am estimating some simple Litterman-prior BVARs. When I generate the impulse responses, the Cholesky ordering seems not to matter to the output (the other variables always responds with a one period lag, regardless of the ordering). Is this normal behaviour?
Re: BVAR IRFs and Cholesky ordering
Postby EViews Gareth » Thu Apr 13, 2023 8:56 am
Which version of EViews, and which type of IRF?
bcfc82
Postby bcfc82 » Thu Apr 13, 2023 6:07 pm
Eviews 13 and Litterman/ Minnesota prior BVARs. IRFs using Bayesian sampling, but I get the same results using the posterior/ empirical residual covariances.
EViews Kai
Postby EViews Kai » Mon Apr 17, 2023 3:53 pm
Yes, impulse response results should be invariant to Cholesky ordering under impulse methods that use a diagonal error covariance matrix.
bcfc82
Postby bcfc82 » Tue Apr 18, 2023 8:26 pm
OK, thanks. So the Bayesian IRF methods impose a diagonal cov matrix?
Postby EViews Gareth » Wed Apr 19, 2023 7:18 am
The Litterman prior does, yes.
