Panel GMM, system estimation and White's diagonal matrix
Postby tvonbrasch » Mon Oct 17, 2022 7:29 am
I have a question regarding system estimation using panel data with GMM and the w-option (White’s diagonal weighting matrix). In what dimensions (if any) does this estimator impose independence of the residuals ? (in addition to assuming that disturbances are uncorrelated with the set of instruments). In particular, does it impose that the sum of residuals is uncorrelated across equations?
Re: Panel GMM, system estimation and White's diagonal matrix
Postby EViews Glenn » Mon Oct 17, 2022 9:38 am
Hi T,
The White diagonal in GMM panel is generally employed when we assume no correlation between residuals across equations, and no correlation between residuals across observations (even within cross-sections). It is a very strong assumption, but doesn't require independence. So under these assumptions, we do not have independence of the sums-of-squares across equations.
Having said that, there is one other (I think important and often overlooked) related point: one can always estimate a GMM or other linear regression model with a weighting matrix which is not optimal given the error structure, so long as the conditional mean is specified correctly. Thus, we can use a White diagonal even if there are various forms of cross-observation and cross-equation correlation. We will get consistency of the coefficient estimates, but not efficiency, and the estimates of the coefficient covariance will not be estimated properly unless we employ a valid robust covariance estimator.
In my view (some might disagree), this result implies that the choice of a weighting matrix doesn't necessarily imply that you are comitting to a particular error structure. Whatever weighting matrix we use, the assumed error structure of the residuals will be an externally imposed assumption unrelated to the choice of weighting matrix. I firmly believe that one really should choose an assumption regarding the error structure, then pick a weighting matrix and covariance estimator for efficiency and robustness properties.
So the bottom line is that I would argue that you'll get independence of the SSRs if you are willing to impose it :)
Hope this answers the question.
-g
Postby tvonbrasch » Tue Oct 18, 2022 12:20 am
Excellent, thanks for your extensive reply, Glenn. This was clarifying. Highly appreciated.
t
