"Floating" plutôt que "Docking" sous Eviews13
Bob
Postby Bob » Tue Oct 04, 2022 4:55 am
(re) bonjour,
Est-il possible de paramétrer Eviews13 pour que toutes les fenêtres soient en mode "Floating" plutôt que "Docking" ?
Merci :)
Re: "Floating" plutôt que "Docking" sous Eviews13
Postby EViews Gareth » Tue Oct 04, 2022 8:50 am
Options->General Options->Appearance->Use Pane and Tabs (turn to off)
Postby EViews Steve » Tue Oct 04, 2022 9:06 am
Technically, turning off Pane & Tab mode just uses the original MDI mode where child windows are kept inside the main application window.
A true floating window (as opposed to a docked pane) can live outside of the main window, but this is not the default. However, once a window is made floating, it should remember this the next time you open that file. This is a feature of the Window placement setting under General Options/Environment/Appearance.
Bob
Postby Bob » Thu Oct 06, 2022 8:44 am
Merci et bonne journée
