EViews 13: @ifirst and @ilast commands
mmiller2
Postby mmiller2 » Tue Oct 04, 2022 4:39 am
The @ifirst and @ilast commands appear to have been broken in the transition from EViews 12 to EViews 13. Please run the following commands in each version:
wfcreate(wf=work, page=a) a 1901 2100 smpl 1950 2021 series x = 1 smpl @all scalar per1 = @ifirst(x) scalar per2 = @ilast(x)
Using EViews 12, per1 = 50 and per2 = 121
Using EViews 13, per1 = 1 and per2 = 72
Re: EViews 13: @ifirst and @ilast commands
Postby EViews Jason » Tue Oct 04, 2022 12:37 pm
mmiller2
Postby mmiller2 » Tue Oct 04, 2022 2:16 pm
Thanks Jason! Any idea when the patch will be available?
Postby EViews Gareth » Tue Oct 04, 2022 3:04 pm
Within a day or two.
mmiller2
Postby mmiller2 » Wed Oct 12, 2022 1:50 pm
There still seems to be something going on with the @ifirst and @ilast functions.
When I run the attached program in EViews 12, I see the following result in the log window.
per1 = 220
per2 = 486
However, when I run the same program in EViews 13, I see:
per1 = 1
per2 = 267
The documentation says, "returns the workfile index of the first non-missing value in the series for the current sample." While, this seems to suggest that the EViews 13 (relative to current sample) result is correct, we have code that is now broken because it has been doing it the EViews 12 way (relative to workfile range) for several years.
test.prg
(189 Bytes) Downloaded 927 times
Postby EViews Jason » Wed Oct 12, 2022 4:33 pm
We will get a patch out ASAP
mmiller2
Postby mmiller2 » Fri Oct 14, 2022 6:03 am
Thanks Jason! I just installed the Oct 13 patch and it's working for me now.
