Database error: Fame library error
magnusastebol
Postby magnusastebol » Tue Aug 02, 2022 4:20 am
When saving forecasts to a database I get the attached error message (last picture). Data are fetched from a Fame database, forecasts are produced and saved to a local eviews database, to be fetched on a later stage. There seem to be a problem with saving to a local eviews database. Not seen this error before. Until recently, the program being used has been running fine for years.
Was not able to upload the database file here. Apparently I am able to save some of my results to the database, but not all. When trying to fetch all the series in the database, I get another error message ("A NULL ptr was given", see Capture2). Any idea what is the problem here?
Re: Database error: Fame library error
Postby EViews Gareth » Tue Aug 02, 2022 5:57 am
How are you storing to the EViews database?
magnusastebol
Postby magnusastebol » Thu Aug 04, 2022 8:39 am
Hi, thanks for the quick reply.
Like this, I store a bunch of forecasted series:
%rekursive_anslag_db="F:\PPO\OKA\Sektorer\Husholdningene\Bolig\Boliginvesteringer\Modeller\Magnus_test2\rekursive.db" dbopen rekursive.db store(d={%rekursive_anslag_db},o) fc_* close rekursive.db
