Add a control variable in Vecm model
chadhughes
Postby chadhughes » Wed Jul 13, 2022 6:37 pm
How To Dust Off Your Ceilings and Walls With A Vacuum Cleaner
The cleaning capabilities of a vacuum cleaner can be extended beyond your ground and furniture. You can use it to remove dust from your painted ceilings and walls, including air vents, window and door trim, picture frames, and moldings.
Those places usually accommodate plenty of dust over time, and a product from the Best Rated Vacuum Cleaners is usually the best way to freshen them up. But if you don't do it the right way, you may hurt your back and scuff the pain. To avoid those risks, have a look at the tips below.
  • Preparation
Before proceeding with the actual dusting, you should remove any items you can from your ceilings and walls, including hanging artwork and picture frames.
They may be dusty too, but it's safer to clean them on the floor than doing so when they're still hanging on the wall. Use a vacuum with a soft brush attachment to dust them off. This can also be done by hand with a dry cleaning cloth.
If there is furniture that you can move but needs to be protected from the falling dust, drape them with blankets or large sheets. Once you're done dusting, roll up these blankets and sheets carefully and shake off the dust. Put on a mask if you have asthma or allergies.
  • Tools
What is the best vacuum for this job? Get a model that comes with at least one brush attachment. You can also buy an extra tool from the manufacturer if you need a bigger dust brush. Make sure it has a HEPA filter as well.
Make sure that there are no metal or hard plastic parts that could come in contact with the surface. They can scuff or scratch painted surfaces or even cause permanent damage to fragile coverings.
If you have natural or textured wallpaper on your walls, a round brush will be a better choice as it usually has softer bristles.
Utilize all the extension hoses and wands coming with your vacuum to extend its reach. Upright models often provide detachable hoses and make this job much easier. If your vacuum still can't reach the ceiling, consider standing on a chair or a step ladder.
  • Dusting
Always dust your ceilings and walls from the top down. Start with the ceilings using the maximum reach of your best vacuum cleaner reviews.
Most dust brushes can contain the dust pretty well while vacuuming, but it's normal for some dust to fall off your ceilings and not get sucked into the vacuum. This fallen dust will land on the walls, floor, and furniture below.
Many canister vacuums have special attachments for ceiling fans, but you can also use regular dusting attachments to get the job done. Gently dust off the blades and paddles, especially on their backsides. Remember to clean the air vents and motor housing as well.
Don't forget to use the brush bristles to get into supply and return vents. They usually harbor a lot of dust, reducing the airflow going across your house. This can become a huge issue and make your cooling and heating system work less efficiently.
Conclusion
Vacuum cleaners with top rated vacuum cleaners and some proper attachments are a great solution to your dusty ceilings and walls. You can freshen up those surfaces with the right techniques without damaging the textured wallpapers or painted surfaces.
