Add VAR exogenous variable shock feature
Thanks very much
Re: Add VAR exogenous variable shock feature
Thanks for the suggestion. This is a matter of interface only since you can easily use the user-defined shocks in impulse responses to simulate an exogenous variable shock. What exactly would you want to be able to do? How much control over the shocks do you want?
