code for SVAR
zezza
code for SVAR
Postby zezza » Thu Jun 30, 2022 10:49 am
Is there any example on how to code the estimation of a SVAR? I am particularly interested in obtaining the responses to structural VAR innovations for producing additional statistics and charts.
The manual mentions the @lrrsp vector, but varname.@lrrsp(1,1) returns a number which does not match any number in the table obtained with View > Impulse response
Thank you
EViews Matt
Re: code for SVAR
Postby EViews Matt » Thu Jun 30, 2022 1:58 pm
There are a few small SVAR examples in the documentation, but I can provide a few more here. To answer you're question about @lrrsp, the accumulated impulse responses that data member holds are the theoretical/asymptotic responses, not the responses at the last horizon as shown in the impulse responses view. As a simple demonstration,
create u 50 series x = 0 series y = 1 smpl 2 50 x = .5 * x(-1) + rnd y = .8 * y(-1) + .3 * x(-1) + nrnd var v.ls 1 1 x y v.impulse(a,imp=unit,se=a) matrix auto_lrrsp = v.@lrrsp matrix manual_lrrsp = @inverse(@identity(2) - v.@lagcoef(1)) show auto_lrrsp show manual_lrrsp
The above code generates a trivial VAR and shows the accumulated impulse responses to unit innovations (for mathematical simplicity), as well as the @lrrsp matrix and a manual calculation of the long-run multiplier, psi. The two matrices should match, and represent the values that the accumulated responses are asymptotically approaching. Examining the response graphs or table, the values at the last horizon should be near those in the matrices though likely not identical.
The same idea holds if you're using EViews' built-in SVAR estimation, were there @lrrsp and @svarfmat matrices represent asymptotic behavior of the accumulated impulse responses. For example,
create u 50 series x = 0 series y = 1 smpl 2 50 x = .5 * x(-1) + rnd y = .8 * y(-1) + .3 * x(-1) + nrnd var v.ls 1 1 x y v.svar(preset=1) v.impulse(a,imp=struct,se=a) matrix lrrsp = v.@lrrsp matrix fmat = v.@svarfmat show lrrsp show fmat
Now, if you what you actually want to capture is the finite (horizon-limited) behavior of the responses as shown in the view window, there are options to copy that data to the workfile. For example,
create u 50 series x = 0 series y = 1 smpl 2 50 x = .5 * x(-1) + rnd y = .8 * y(-1) + .3 * x(-1) + nrnd var v.ls 1 1 x y v.svar(preset=1) v.impulse(a,imp=struct,se=a,matbyr=responses) show responses
zezza
Re: code for SVAR
Postby zezza » Fri Jul 01, 2022 3:22 am
Thank you, you have been very clear, and the code works on my data!
zezza
Re: code for SVAR
Postby zezza » Fri Jul 01, 2022 4:18 am
One last question: Is there a way to get a matrix of the standard errors of the responses, to reproduce the charts with the confidence intervals?
Thank you
EViews Matt
Re: code for SVAR
Postby EViews Matt » Tue Jul 05, 2022 3:14 pm
When using 'matbyr' or similar options, a second matrix with the suffix "_se" is created to hold the standard errors. So in my example code, matrices "responses" and "responses_se" are created as part of the impulse procedure.
zezza
Re: code for SVAR
Postby zezza » Tue Jul 12, 2022 10:26 am
Thank you! I should have noticed...
