save table as pdf
dsd0712
save table as pdf
Postby dsd0712 » Wed Apr 20, 2022 12:40 am
If I save a spool object as a pdf, the Swedish letters (å ä ö) will not be printed correctly. If, on the other hand, I choose print to pdf, it will be right. Is there a setting that needs to be changed, or is this an unresolveable bug?
Re: save table as pdf
Postby EViews Jason » Wed Apr 20, 2022 11:25 am
The PDF engine used in a 'save' is different than the engine used when printing. Unfortunately, until the PDF save engine is replaced there isn't much that can be done.
