Dependent/Independent Variable Distinction
pbrownster
Postby pbrownster » Sun Apr 04, 2010 8:11 am
I have one explanatory dummy variable and several
Re: Dependent/Independent Variable Distinction
Postby startz » Sun Apr 04, 2010 8:38 am
I have one explanatory dummy variable and several standard variables which are technically dependent on the dummy.....can i use the dummy as the dependent variable in a LOGIT regression against the other variables? or is it not possible to swap the dependent/explanatory variables?
I realise this might be quite a stupid question but im a little bit lost..
It is not possible to switch the dependent/explanatory variables.
What you may want to do is use the System object to set up a "seemingly unrelated regression" model.
Or more simply, just regress each variable separately against the dummy.
