RConn library error
RConn library error
Postby startz » Fri Nov 12, 2021 11:45 am
Help please on fixing
Screenshot 2021-11-12 104405.png (4.16 KiB) Viewed 13375 times
when trying to read in an .RData file using File/Open/Foreign Data
Re: RConn library error
Postby EViews Steve » Fri Nov 12, 2021 2:28 pm
Do you have R installed? You'll need it if you want to open an RData file. If you do have it, make sure EViews is pointing to the correct R Home directory under Options menu/General Options/External program interface.
Postby startz » Fri Nov 12, 2021 2:32 pm
Updating the R home directory fixed it.
R gets updated fairly regularly. Makes me wonder whether there could be an option to look in the registry or somewhere and find the current version, if that's what someone wanted.
Postby EViews Steve » Sat Nov 13, 2021 3:51 pm
We do look in the registry to try and find a default R home directory. But we don't do that if you already have a value filled in.
Postby startz » Sat Nov 13, 2021 4:52 pm
My thought is a user-settable option saying to look in the registry. Probably best not the default.
