BVAR forecast Error "missing data"
Hello, each time i try to use the forecast function in a BVAR (Eviews 11) i get the error "unable to compute due to missing data". There is no missing data in my dataset. Any suggestions?
Re: BVAR forecast Error "missing data"
Could you provide the workfile?
Weird. I made a fresh workfile with the same data to attach and now it works. The only thing i did different was to cut off the dataset so there were no missing values (some of the data goes back to 2000, one series starts midway 2006).
I am getting a "c already exists" error now when i try to forecast from a second estimated VAR.
- bvar stuff.wf1
- (80.16 KiB) Downloaded 702 times
Seems to work for me. What's the build date of your copy of EViews 11? (Help->About EViews)
enterprise edition, June 9, 2021
Could you describe exactly what you do that produces the error (starting with opening the workfile you posted).
So, now if i download the file I attached, it works. But it does not work in the original file i uploaded (if that makes sense). I feel like the guy with the singing frog in the old warner bros cartoon.
the issue might be the fan charts. It works fine unless I select fan charts as an output
