Automatic arima forecasting in a program
albertliu
Postby albertliu » Sun Oct 03, 2021 7:07 am
Dear sir / madam,
I recently discovered that you could do automatic arima forecasting in eviews. My question is if it is possible to write a program in Eviews such that I can apply this tool to multiple time series at once because now it is only possible to do one time series at a time which is time consuming. Lastly, When I did this manually, it gave me different models when I ran it even though I did not change any setting So I was wondering how accurate this automatic arima forecasting is?
Re: Automatic arima forecasting in a program
Postby EViews Gareth » Mon Oct 04, 2021 9:41 am
Yes, you can program it:
http://eviews.com/help/helpintro.html#p ... 23ww201049
It shouldn't give different results. Perhaps you could provide details?
albertliu
Postby albertliu » Tue Oct 12, 2021 7:24 am
Dear Gareth,
I found another way to program it via another language in the meantime but still thank you for your answer!
uyanikcaner
Postby uyanikcaner » Mon Sep 26, 2022 6:23 am
Hello everyone. After updating my Eviews 12 to Eviews 13 I am no longer able to run the autoarma program codes to make automatic arima forecasting. Everything is the same in the programme file, when I run the code on Eviews 12 it works. However, when I run the code on Eviews 13 it gives this warning: "Error in Sample: Range Error in "HBETON.AUTOARMA
(MAXAR=10, MAXMA=10, MAXSAR=1, MAXSMA=1,
SELECT=MSE, FORCLEN=1, MSETYPE=1) HBETON_F C
@EXPAND(@MONTH, @DROP(LAST))" on line 187."
When I try to make automatic arima forecasting by using "Proc" button, it gives again a warning of "Math Error has resulted in loss of precision"
Could you please help me?
Sincerely,
Caner.
Postby EViews Glenn » Mon Sep 26, 2022 6:36 am
Sorry for the inconvenience. We will take a look.
Postby EViews Glenn » Mon Sep 26, 2022 9:11 am
Is there any chance you can post the workfile at the point where you try to run this and get the error?
uyanikcaner
Postby uyanikcaner » Mon Sep 26, 2022 9:41 am
Is a screenshot okay or you want to run the program file on the workfile that I am currently working on?
Postby EViews Glenn » Mon Sep 26, 2022 1:33 pm
I'd like to run, if possible. I can't replicate for a test workfile with the forclen properly set to be after the estimation sample end.
Absent that, if you can tell me the estimation sample and the workfile sample and the forecast length.
uyanikcaner
Postby uyanikcaner » Tue Sep 27, 2022 1:48 am
I attached a workfile and a prg. document here. I hope you can see them.
Postby EViews Glenn » Tue Sep 27, 2022 9:14 am
They didn't show up. Could you try to include again? Or send to support@eviews.com
uyanikcaner
Postby uyanikcaner » Tue Sep 27, 2022 11:54 pm
I have just sent the files to support@eviews.com
uyanikcaner
Postby uyanikcaner » Thu Sep 29, 2022 1:06 am
Is there any update on this issue? When will this problem be solved and the new patch be released?
Postby EViews Gareth » Thu Sep 29, 2022 9:46 am
Patch has been released.
tolosag
Postby tolosag » Thu Apr 04, 2024 12:45 am
how can I choose the AR and MA models without using piloting the ACF and PCAF graph, I mean, I want an automatic single Eviews command to select the best ARIMA model.
Postby EViews Gareth » Thu Apr 04, 2024 11:48 am
