I want to use the Hausman Test in order to check whether my panel data allows to use random effects models instead of fixed effects models. I know how to perform the test, I just have difficulties with the interpretation of the output and the warnings that I get. I already searched the Eviews User Guide and this forum, but I am still confused and I hope that you can help me. My Hausman output looks like this:
Test Summary Chi-Sq. Statistic Chi-Sq. d.f. Prob.
Cross-section random 0.000000 16 1.0000
* Cross-section test variance is invalid. Hausman statistic set to zero.
** WARNING: robust standard errors may not be consistent with
assumptions of Hausman test variance calculation.
My questions are:
1) Does the warning mean the test is invalid?
2) If "yes" to question 1), what can I do?
3) May I use random effects panel models?
One maybe important information: I use White (diagonal) robust standard errors. I use Eviews version 6.
Thank you very much and enjoy your easter holidays!
Warnings & Interpretation Hausman Test
Re: Warnings & Interpretation Hausman Test
Essentially what this is saying is that the estimate of the cross-section effects indicates that there are, in fact, no cross-section effects (i.e. they have no variance). This means that testing for the difference between random effects and fixed effects may not be a valid thing to do (if your best guess is that there are no effects, how can you test what sort of effects they are?).
There isn't really a "fix" for this, nor should you really think of it as a problem.
Cross-section random 0.101977 1 0.7495
WARNING: estimated cross-section random effects variance is zero**
Hi!
I'm getting this message.
What does it mean for my model????
Hi!
