Negative R square
Miskolak
Negative R square
Postby Miskolak » Sat Aug 21, 2021 4:03 pm
Hi all,
I'm running least squares estimations using WTI data and stock market data.
I have adjusted the data for inflation. Logged both data sets, took the first difference to find the rate of growth, and multiplied the data by 100.
When I've regressed the variables, I get a return of a negative r square.
Am I misspecifying the equations? Using wrong data?
I don't know where I'm making the mistake. As I'm trying to establish the extent to which growth in WTI affects the growth in stock markets.
Thank you for all the help and wish you all the best.
Re: Negative R square
Postby EViews Gareth » Sat Aug 21, 2021 4:04 pm
Do you have a constant/intercept?
Miskolak
Postby Miskolak » Sat Aug 21, 2021 4:14 pm
Hi, yes I do.
When estimating I type in : STOCK = C(1) + WTI(2) + Lag1WTI(3) + Lag2WTI(4) + Lag1Stock(5) + Lag2Stock(6)
Additionally, when I add lags the R square becomes more negative.
Postby EViews Gareth » Sat Aug 21, 2021 4:37 pm
That specification is almost certainly not correct. You probably want:
stock c wti lag1wti lag2wti lag1stock lag2stock
Miskolak
Postby Miskolak » Sun Aug 22, 2021 8:03 am
That fixed it, thank you very much.
