I used the Easther codes of rolling regression for one step ahead forecasting, and I would like to generate rolling forecasting evaluation as well, this is the code that Im using:
' set window size
!window = 729
' set step size
!step = 1
' get size of workfile
!length = @obsrange
' declare equation for estimation
equation eq1
'calculate number of rolls
!nrolls = @floor((!length-!window)/!step)
'matrix to store coefficient estimates
matrix(3,!nrolls) coefmat ' where 3 is the number of coefficients
'series to store forecast estimates
series fcast
' vector to store forecast evaluations
vector (!nrolls) RMSE
vector (!nrolls) THEIL
'*EDITED: catching start and end points
%start = "@first" '@otod(@ifirst(ser))
%end = "@last" '@otod(@ilast(ser))
'variable keeping track of how many rolls we've done
!j=0
' move sample !step obs at a time
for !i = 1 to !length-!window+1-!step step !step
!j=!j+1
' set sample for estimation period
%first = @otod(@dtoo(%start)+!i-1)
%last = @otod(@dtoo(%start)+!i+!window-2)
smpl {%first} {%last}
' estimate equation - where the equation is P =c(1) + c(2)*P1(-1)
eq1.ls(cov=hac) price c load ng
' store coefficients
colplace(coefmat,eq1.@coefs,!j)
' 1-period-ahead forecast
%1pers = @otod(@dtoo(%start)+!i+!window-1) 'start point
%1pere = @otod(@dtoo(%start)+!i+!window) 'end point
'*EDITED
if @dtoo(%end) < @dtoo(%1pere) then 'check whether the forecast end point is greater than the workfile end point
exitloop
endif
' set smpl for forecasting period
smpl {%1pers} {%1pere}
' forecast with command *forecast* (see also *fit*)
eq1.forecast(f=na) price_nordf
' set sampl to obtain the 1th period observation
smpl {%1pere} {%1pere}
' Forecast evaluation
!RMSE = @rmse(price, pricef)
!THEIL = @theil(price, pricef)
' store forecasts
fcast = price_nordf
smpl @all
show coefmat
show fcast.line
d(noerr) price_nordf
The problem is that these codes dont generate the vector of RMSE and THEIL for rolling evaluation of forecasts, can someone please help me where is the problem in my codes?
Shwan
Rolling forefasting evaluation
Re: Rolling forefasting evaluation
I'm not too confident, but I think I can point out two things.
First, you store the forecasts in "price_nordf", not in "pricef".
Second, the "!RMSE"(!THEIL) is just a new control variable; it is not related to the predefined vector, "RMSE"(THEIL).
So my suggestion is;
RMSE(!j, 1) = @rmse(price, price_nordf)
THEIL(!j, 1) = @theil(price, price_nordf)
Please confirm the results well.
Hope this helps.
Hope this helps.
