Correct way to set up auto-update functionality ("Invalid XML was found.")
For tips, questions and general information about writing Add-ins, how to package them, and how to submit them to EViews for publication.
CrisisStudent
Postby CrisisStudent » Wed Apr 21, 2021 2:06 am
Hi all,
I have posted add-in on Eviews site, but did not realize the update does not function properly. There were initially some mistakes on my part, but even after fixing those I still get message "Invalid XML was found.", so I must be still missing something.
The fixed add-in package is attached, below is the instalation command and XML file. Could you help me with fixing it?
Thanks!
CrisisStudent
addin(type="equation",menu="Specifiation(s) evaluation",proc="speceval",docs=".\documentation\specification_evaluation.pdf",desc="Performs evaluation of (forecasting properties of) equation(s) and prepares report summarizing the results.",url="https://github.com/CrisisStudent/SpecEval/blob/master/update_info.xml",version="1.0") ".\specification_evaluation.prg"
<item> <title>speceval</title> <path>specification_evaluation.prg</path> <version>1.0</version> <description>Performs evaluation of (forecasting properties of) equation/VAR/identity object(s) and prepares report summarizing the results.</description> <link>https://github.com/CrisisStudent/SpecEval/blob/master/Package/SpecEval.aipz</link> <pubDate>4 Apr 2021</pubDate> </item>
Re: Correct way to set up auto-update functionality ("Invalid XML was found.")
Postby EViews Gareth » Wed Apr 21, 2021 6:46 am
The issue (and it is common with github) is that the address you're using isn't just the raw XML - the site has all the other github stuff around it.
Use this link instead:
https://raw.githubusercontent.com/CrisisStudent/SpecEval/master/update_info.xml
CrisisStudent
Postby CrisisStudent » Wed Apr 21, 2021 7:48 am
Thanks Gareth!
It helped, as now Eviews manages to check for the update. However I encounter problem when I confirm that I want to update the file. For the add-in mentioned above I get error
"SPECEVAL: Error encountered during install - Could not open file due to: unknown error."
. I also tried for other add-in and there I get
"COLORCODE: Could not retrieve AIPZ file"
This is after I have changed the path also in the update_info.xml file, which is now following:
<item> <title>speceval</title> <path>specification_evaluation.prg</path> <version>1.0</version> <description>Performs evaluation of (forecasting properties of) equation/VAR/identity object(s) and prepares report summarizing the results.</description> <link>https://raw.githubusercontent.com/CrisisStudent/SpecEval/master/Package/SpecEval.aipz</link> <pubDate>4 Apr 2021</pubDate> </item>
Postby EViews Gareth » Wed Apr 21, 2021 8:08 am
Same issue. Your XML file:
Has a link which is the generic github link - you'll need to replace the link with the raw.
CrisisStudent
Postby CrisisStudent » Wed Apr 21, 2021 8:15 am
That's what I thought, but I already fixed that (see code in my last reply).
Also, when I use that link, the installation package downloads and runs correctly.
Postby EViews Gareth » Wed Apr 21, 2021 9:18 am
The XML file right now doesn't have the raw part.
https://raw.githubusercontent.com/Crisi ... e_info.xml
CrisisStudent
Postby CrisisStudent » Wed Apr 21, 2021 12:36 pm
Ah, yeah, I did no push online, of course. When I fixed this then the update for the other two add-ins works. But for SpecEval I get message that Installation failed (it works when I run the link directly). Any way to check what is going on? All the updated files are now on the GitHub site.
Postby EViews Gareth » Wed Apr 21, 2021 12:41 pm
Just tried it, and it worked for me.
CrisisStudent
Postby CrisisStudent » Wed Apr 21, 2021 11:42 pm
Well, after restart it worked for me too. Moody computers, I guess. :shock:
Thanks a lot for all your help!
Return to “Add-in Writing area”
