Hello everybody,
I want to estimate the dynamic response of GDP to a unit shock og government expenditure.
In first stage, I estimated the structural VAR (the A and B matrices); then, using the impulse definition tab, I have the impulse responses of an expenditure shock (shock 2) in the attachement.
In the impulse response graph, the value of the first shock of expenditure (dlog(depensesa) in my case) is zero "0", but I want to have a one unit shock.
So my question is how can I obtain this shock with first value = "1".
Thank you for your help.
structural VAR and impulse response function
Re: structural VAR and impulse response function
In most VARs, a shock only has a contemporaneous effect in its own equation. So unless you've done something special, you're getting the expected result.
Thank you startz for your reply
