In the pyeviews module there is an option to pull eviews workfiles into a pandas dataframe using pyeviews.GetWFAsPython. Is there a way of importing an eviews database file (".edb") into a pandas dataframe? Or can anyone think of a workaround for doing this?
Python access to eviews databases
Re: Python access to eviews databases
There isn't a way to do it directly, but you can always create a workfile, open the EDB file, fetch the objects you want to the workfile, then get the workfile data. You would use the Run method to do all of the initial steps.
For example:
For example:
evp.Run('WFCREATE A 1990 2000', app=eviewsapp)
evp.Run('DBOPEN mydb.edb', app=eviewsapp)
evp.Run('FETCH x y z', app=eviewsapp)
x = evp.GetWFAsPython(app=eviewsapp)-
projectseeker
Great, thank you.
Be careful you keep frequencies the same - no error will occur if you create an annual workfile and fetch a quarterly series into it.
