Hi all!
I'm working with several years of daily data, and I need to generate a dummy variables that is 1 if the average of weekend values is greater than the average of weekday values, and 0 for the opposite.
I figure I could start by creating a series that is the average of just the weekday values, and another that is the average of just the weekend values, then create a series using @recode that is 1 or 0 depending on the above inequality.
Is there a slick way to create these average series? Or, better yet, a better way to do this than my line of thinking?
Thanks!
Bob
weekday vs weekend average
EViews Matt
Re: weekday vs weekend average
You have the right idea, which can be simplified to something of the form:
series dummy = @mean(x, "if @weekday > 5") > @mean(x, "if @weekday <= 5")
Thank you! This is a good start.
One wrinkle I forge to include is that this must evaluate the means on a week to week basis, or each week has it's own unique mean for the days just in that week. Any thoughts on how I'd add that into the mix?
I was thinking I could loop the week numbers through the smpl command in the loop.
EViews Matt
With the simplifying assumptions that a week begins on Monday and year boundaries should be ignored, I believe the following will work:
series dummy = @meansby(x, @date-@weekday, "if @weekday > 5") > @meansby(x, @date-@weekday, "if @weekday <= 5")
Thank you again.
And one last step.
I now need to convert this daily variables, into a weekly variable, that is 0 if the weekday average was less than the weekend average, and 1, if the weekend average was greater than the weekday avarege.
Thank you again!
And one last step.
Thank you again!
I simply used the recode function with an equality for if dummy < 1,0,1
hank you again for all the help!
