Page 1 of 3
Error "Variable is not defined" in panel ARDL
Posted: Fri Jan 01, 2021 8:58 am
by nhunghatinh
Hi everyone. I am a new member. Nice to join this forum. Could you please help me with my problem
I am running panel ARDL for a panel data set. My model: lco2 lfdi lgdp lgdp2 ltrade lurbanization
All variables are I (1). When I run ARDL model for this panel data set, it says "lco2 is not defined", and when I changed lgdp to become dependent variables, it also says "lgdp is not defined". In general, It has the same notification when another variable is chosen as the dependent variable. I have been stuck for a few days and feel frustrated. :(. I am using eviews 11 student version (the trial version provided by eviews).
Please take a look and help me if you can. Thank you so much
Re: Error "Variable is not defined" in panel ARDL
Posted: Fri Jan 01, 2021 10:27 am
Do you have a variable with that name in your workfile?
Posted: Fri Jan 01, 2021 6:15 pm
by nhunghatinh
Hi EViews Gareth. Thanks so much for your reply. I do types the name of variables correctly. I think the problem occurs with any variables chosen as dependent variable.
Posted: Fri Jan 01, 2021 7:56 pm
by startz
There are two things you might do that would be helpful.
(1) Post the build date of your copy of EViews. (Help/About EViews)
(2) Post your workfile, including the VAR object you are trying to estimate.
Posted: Sun Jan 03, 2021 6:07 pm
by nhunghatinh
THanks startz
Hi. As the trial version does not allow me, I can not send the eviews file.I have posted the excel file here. Hope that everyone can help me. Really look forward to hearing from you
Posted: Sun Jan 03, 2021 6:39 pm
by nhunghatinh
THanks startz
Here is screenshot
Posted: Mon Jan 04, 2021 7:01 am
by startz
lco2 is not in the Excel spreadsheet you uploaded.
Posted: Tue Jan 05, 2021 7:49 pm
by nhunghatinh
Thanks for replying. But I create the log variable in the eviews (as you can see in the post)
Posted: Tue Jan 05, 2021 8:10 pm
by startz
I see that it is in the picture, but I don't know how you created the variable. I also don't know how you created the other variables that are not in the Excel workfile.
Also, while it is very unlikely that you've hit a bug it is not impossible. It would help the EViews team if you told them the build date of your version.
Posted: Tue Jan 05, 2021 9:17 pm
by nhunghatinh
Thanks so much for replying startz. I transform variable into log form, the original is not in log form. That is why you dont see the log variable in the spreadsheet. I can not send you the workfile as i am using Eviews 11 student lite version (which has many limitations), which does not allow to save my file. Would you mind transforming my data to log form and run ARDL in your eviews to see if you have similar errors? I am using macbook, which causes me difficult to install eviews without buying it. I attached a picture of the eviews version . Hope to hear from you
Posted: Tue Jan 05, 2021 9:27 pm
by startz
What is gdp2? It is not in the Excel file.
Posted: Tue Jan 05, 2021 10:41 pm
To follow on from Startz' question(s), it would be extremely helpful if you could outline exactly what you do to get from the Excel file you provided to the error message you see.
It is frustrating to people, who are only trying to help you, to have to keep asking you the same thing.
Posted: Wed Jan 06, 2021 6:52 am
by nhunghatinh
Thanks so much for your help startz. I will stop asking this question.
Posted: Wed Jan 06, 2021 6:53 am
by nhunghatinh
Hi. Thanks for your feedback. You do not understand me because I can not save the work file and post here (this lite version do not allow me) so that it is easier for you to understand. I will stop asking this question. Thanks
Posted: Wed Jan 06, 2021 6:56 am
by nhunghatinh
Thanks so much for your help startz. Really appreciate your time and effort. I will stop asking this question.
