Dear All
Greeting
I'm doing an estimation using PMG, my panel structure is T(2000-2019, N=78). I don't have any dummy variables, when u run PMG, I received "Near singular matrix". When I tried in STATA is working. What do you suggest?
Near singular matrix, PMG
Re: Near singular matrix, PMG
In general, Stata silently drops variables when there is perfect multicollinearity while EViews gives a warning message instead. You might post your EViews file including the equation to be estimated.
Dear , Sir
Attached you will find my reviews file, I want to estimate the following equation
CON1 CUR EDU FDI FIN2 INF2 GOE TR UNE Y1
Regards
Regards
- eviewsnew.wf1
- (510.78 KiB) Downloaded 504 times
Dependent Variable: CON1
Method: Panel Least Squares
Date: 12/28/20 Time: 06:07
Sample (adjusted): 2000 2018
Periods included: 18
Cross-sections included: 61
Total panel (unbalanced) observations: 755
CUR -8.12E+09 1.86E+09 -4.364800 0.0000
EDU -33963273 27122296 -1.252227 0.2109
FDI -2.22E+08 1.75E+08 -1.269897 0.2045
FIN2 1.26E+08 50515644 2.489889 0.0130
INF2 7.08E+08 1.57E+08 4.512228 0.0000
GOE 5.377901 0.039234 137.0715 0.0000
TR -45312197 35269080 -1.284757 0.1993
UNE -8.21E+08 1.78E+08 -4.618991 0.0000
Y1 1.25E+09 2.73E+08 4.589057 0.0000
Root MSE 2.59E+10 R-squared 0.966630
Mean dependent var 4.67E+10 Adjusted R-squared 0.966272
S.D. dependent var 1.42E+11 S.E. of regression 2.61E+10
Akaike info criterion 50.81722 Sum squared resid 5.07E+23
Schwarz criterion 50.87238 Log likelihood -19174.50
Hannan-Quinn criter. 50.83847 Durbin-Watson stat 0.196020
Hello
Thanks, but in my case what is problem with PMG?
Regards
Regards
Your workfile did not include the equation you estimated. Either include that equation or post the exact command you used.
I selected the same variables that you estimated today, but I selected ARDL/PMG. Could you please help?
Note that you have a lot of NAs. I suspect that once lags are included there isn't any data left.
I agree with you, that what I thought, anyway, thanks a lot for help and spport
Regards
Regards
