normal wishart
gerluc
normal wishart
Postby gerluc » Tue Jul 14, 2020 11:24 am
hello. when running a normal wishart bayesian var, why is it not possible anymore in EViews11 to set prior for Lambda1?
Re: normal wishart
Postby EViews Gareth » Tue Jul 14, 2020 11:31 am
It doesn't exist in the Normal-Wishart prior. It is "replaced" by the C hyper parameters.
gerluc
Re: normal wishart
Postby gerluc » Tue Jul 14, 2020 11:36 am
what do you mean by "replaced"? In what sense? please elaborate. thank you
Re: normal wishart
Postby EViews Gareth » Tue Jul 14, 2020 11:38 am
gerluc
Re: normal wishart
Postby gerluc » Tue Jul 14, 2020 11:44 am
is it because of the H kronecker product Sigma for the prior in beta in equation (44.18)?
Re: normal wishart
Postby EViews Gareth » Tue Jul 14, 2020 12:03 pm
Equations 44.18 through 44.22 have no lambdas. But in previous versions of EViews we abused notation by using lambda instead of C in 44.22.
gerluc
Re: normal wishart
Postby gerluc » Tue Jul 14, 2020 12:21 pm
C3 is the degrees of freedom parameter. Is that too high to be a prior variance for mu1?
gerluc
Re: normal wishart
Postby gerluc » Tue Jul 14, 2020 1:02 pm
Or, should i take the inverse of C3 to obtain prior variance of Mu1?
gerluc
Re: normal wishart
Postby gerluc » Tue Jul 14, 2020 1:50 pm
What does S scale and V scale mean in the dialog box?
Re: normal wishart
Postby EViews Gareth » Tue Jul 14, 2020 1:57 pm
Its a description of what C1 and C2 are.
gerluc
Re: normal wishart
Postby gerluc » Tue Jul 21, 2020 8:14 am
Hi Gareth,
Let me come back to this topic. On equation 44.22, page 807 of the Eviews11 manual to obtain the covariance terms of a normal wishart, how come the C1 hyperparameter is not found in the three equations? Should H_inverse of NW = C1*I (identity with dimension k), and not as presented in that same equation?
Re: normal wishart
Postby EViews Gareth » Tue Jul 21, 2020 8:53 am
Ah, that's a typo.
The first line should be C1, the second line should be C2 and the third should be C3. Apologies.
Re: normal wishart
Postby EViews Gareth » Tue Jul 21, 2020 8:57 am
gerluc
Re: normal wishart
Postby gerluc » Tue Jul 21, 2020 10:02 am
Thanks, Gareth. Makes more sense now.
