Hi, I am trying to create a series say "VC", where the first observation of this series "VC" is 100 and from the second observation onwards use the formula series VC=(1+HP)*(VC(-1)), where HP is a series of growth rates. Please, if someone could help me would be very appreciate.
Series creation with growth rate
Re: Series creation with growth rate
series vc =100
smpl 2 @last
vc = (1+HP)*VC(-1)
superjocker
Thanks, but it didnt work, actually I had tried something similar with the same result, just NAs. No problem creating the VC=100 series, but then when defining the smpl and running the formula, just get NAs.
What's in the HP series?
superjocker
just growth rates likeWhat's in the HP series?
na
0.03
0.05
0.07
0.08
0.001
0.025
so I need to end up with
series VC
100
103---------->100*(1+0.03)
108.15---------->103*(1+0.05)
Perhaps post your EViews workfile.
superjocker
'fondo A
import "D:\Usuario\eorellana\Desktop\Box Sync\Eduardoraran\AFPs\RENTABILIDADES FONDOS.xlsx" range="HISTORICOS A"!$AS$3:$AU$20000 colhead=1 na="#N/A" @freq D7 9/26/2002 @smpl @all
'UF
import "D:\Usuario\eorellana\Desktop\Box Sync\Eduardoraran\AFPs\UF Actual.xlsx" range="UF Diaria"!$A$1:$C$20000 colhead=1 na="#N/A" @freq D7 9/26/2002 @smpl @all
series vc_areal=100
smpl 2 @last
vc_areal=(1+(((1+rent_diaria_a)/(1+rent_diaria_uf))-1))*(vc_areal(-1))
What I gave you was a simplification but (((1+rent_diaria_a)/(1+rent_diaria_uf))-1)) is just a rate. Also I am importing data from an Excel from an specific range, dont know if that is doing something.
'UF
series vc_areal=100
smpl 2 @last
Save your workfile to something like foo.wf1 and post that. That's the only way for anyone else to see what EViews thinks it has.
superjocker
The formula:
series vc_areal=100
smpl 2 @last
series vc_areal=100
smpl 2 @last
- FOO.WF1
- (1.1 MiB) Downloaded 286 times
Use:
rather than
Your workfile is dated, so "2" corresponds to the date "2" rather than the 2nd observation.
smpl @first+1 @last
smpl 2 @last
superjocker
Thank you, it worked!!! thank you very much, you are the best.
Thank you again
Thank you again
